I am running the original front mount style distributer, I checked my timing gear timing and it is at the 0 degree mark, but I have not checked the cam itself to see if its correct, that might be worth looking at. I am using the max 1 cam shaft. I am running 115 octane gas and the compression is probably too high, compared to my other motors. I didn't plan it to be that high, but I bought the cast heads at an auction and I am guessing they have been decked more then normal, the actual compression checked at 190. I intend to cc these heads and see what they check at but I haven't done that yet. I have played with the timing slide on the side and at the moment it is fully retarded. I have not functionally checked the timing with a light yet, not sure if it has a mark or not, I will have to check that. Does anyone have a link on how to check the actual cam timing on the cam to match the card, I have never done that.
