barkleydave
We just finished replacing the timing gear and pan gaskets on a 31 Slant.
Prior to taking apart there was an oil leak around the junction of the timing gear inspection cover and the pan. There were other leaks and now those have been corrected. Oil still leaking around the bottom of the timing inspection cover where it joins with the oil pan.
Suggestions for correcting this leak appreciated.
Thanks
*Timing gear was trashed because someone had assembled the plunger without the compression spring!
Thanks
