Could you post a picture of what you have??
Bob
I have lots of timing gear covers. There is early & late. Let me know if you still need one
I wonder if somebody cut the cover back so the belt would line up because the first picture you posted of your generator looks like the pulley is to far forward.
I measured a cover and the generator mount is just a hair under 2" wide.
Yeah Tom W. told me it looked like that as well....i just measured the generator mount and it is 1.5", and the side towards the firewall has been cut i can fill it.
Bob
You could add a spacer or thick washers.
Yeah it had a 3/8" thick hand made aluminium square spacer......I want to put it back to the original way it should be (done right), ever since tuning Clyde up he doesn't seem to run as smooth as hes supposed to ( I think), so im thinking the timing marks may not be lined up correctly as well.....i am tossing around the idea of getting a Snyders HC head, and the correct water pump and timing cover, and then see if the pulleys line up, some one really rushed this together!!!!!!!, id show the wiring harness in the front but am to embarrassed.
Ill give you the B cover if you want it?I run a B distributor with an A cover and would trade if you were interested.
Don't worry about the cover lining up when you set the crank gear and cam gear timing marks. BTW your B cover shown will set the timing at 9 or 10 degree advance, so now is the time to install the correct A cover.
Once these 2 are clocked correctly, you install the cover and set the distributor timing by the pin in the cam gear dimple.
Here's a picture of the gears in mesh.
I wonder if the timing cover has been modified for some reason? The Model A and Model B generators are the same mount.
Charlie Stephens
