Manual or automatic advance?
I have the same head on my car. Bottom line is it depends. If it is too advanced you may ruin the rod bearings by pounding. There is a knee in the advance curve that is pretty close to the correct timing. When ascending a grade, start with the timing lever in about the center of the range. Then advance it one notch at a time. The engine will run better with each notch (pull stronger). You will reach a point where another notch will not improve the engine performance. Go back one notch. That is the knee in the curve. I will be a little conservative and go back two notches. When you get home, count the number of notches to full advanced so that you can go back to the knee setting. You can put a clamp of some kind at the knee setting as a stop. I do that on my car.
Some owners will advance the timing beyond the knee if they are cruising down the highway with medium throttle at about 45 or 50 mph, but I think that is unnecessary for the higher compression heads and dangerous as, in my case, I will forget to put the timing back to the knee.
Each notch is about 4 degrees advance. So you can figure out how many degrees of advance the knee is by counting the notches from the fully retarded position, assuming fully retarded is at zero advance.
The knee may move to another position depending on if you are lugging the car at low rpm. In which case it is best to be conservative and retard the spark a little. When backing up the hill to back into my garage I will retard the spark as it makes the car a little more controllable at the lower rpm.
If your hearing is good enough, mine isn't, you can hear knocking when the timing is too advanced. This is a dangerous condition for the engine and can ruin the rod bearings in short order.
