"Flapper" was running fine but I opted to install a "Zipper" distributor from FS.
After some fumbling I got her running and went for a spin. She ran grate but I thought I would try to improve on "good enough".
I set TDC with the timing pin and the rotor at #1 plug. She would not start. I looked in the distributor body and the rotor was 180' off. Yes I checked the timing pin again and each time the result was the same. The set screw in the head to hold the distributor body in position is tight.
What am I missing here? The distributor worked fine on the test drive.
Please advise
Loyd Nix
Please advise
Loyd Nix
