Just for fun, we made some road tests on a four banger.
We had tried on it : a stock model A head and a 6.0 snyder's head, a model A distributor, a model B dist. and a model A with 30° max nu-rex automatic advance, some ignition advance timing, model B camshaft (was in the block when we bought it), model A and B carb on model A intake, also some work on seat valves, ports and valves, ...
We recorded that :
_ with a model B camshaft, a model A carb, 6.0 head and automatic advance (approx 7atdc to 23 degrees btdc on crankshaft) the engine start and idle perfectly but overheat when we ran. If we opened the GAV, the rpm droped.
_ We changed to 28 to 30 max degrees. It ran quieter but we didn't saw a very significant power increase. If we opened the GAV, it didn't ran well.
_ When I opened GAV (1/2 turn) and modified carb float level (up), I could increase crankshaft degrees to 40. Probably more. The engine seemd to be very strong from 1500 to 2200 rpm but, with more than 10° at idle, it made ping under 1500 rpm. At higher rpm it was noisy (loud).
Did anyone show the same effects of the GAV/gas level on a banger ?
We recorded that :
