Timers
My 15 touring came with a New Day timer.Found a broken spring on brush causing it to missfire. Repaired with a ball point pen spring and has been working fine. In replacing unit is a New Day a good unit or is there a better unit that is reliable. I want to carry spare assy.
You can get the internal pieces from snyders, but I don’t think new ones are made any more. Our family has been using them for almost 70 yrs and think they are the best ones to have.
I have bought used spares from eBay and remachined them.
IMO
The Anderson Timer is also excellent. They tend to run slightly more advanced than the New Day, so you may have to re-bend the timing rod.
I agree. New Day is the best. I too pick them up at swap meets when I can find them. The old roller types are prone to wear.
The Anderson timer does not have a roller. It has a 'flapper'. Much better than the original Ford with the roller.
A fellow/friend in Spokane, WA has produced a very nice copy of the New Day Timer - just installed one our '19 Centerdoor but due to weather conditions haven't got to take her out to try it out yet !
It is important with the original roller style timer to align the front cover with the cam shaft. There are tools available to do that. If you don't, the roller will not spin concentrically, and will chew into the insulation. I've been there. The new day style would seem less prone to this if the cover is out of alignment.
