That group of timers are for the normal Ford magneto and coils, but have different design to improve on life.
The New Day is a brush style, with a forward facing brush making contact with terminals in the face of the housing.
T timers are normally Ford style roller contact, with roller making contact with terminals in the inside edge of the timer.
Then, there is the flapper type, Anderson, which has a hinged flapper that makes contact with steel terminals around the inside edge of the housing.
Photo one shows (l to r) the Ford, the New Day and the Anderson
TW timer is the newest one, which is brush type, using a carbon brush making contact with terminals on the inside edge of the housing. The TW is complete with new housing, but similar to old timer called the M-F.
Lastly, the E-Timer is completely different, using a Hall Sensor, and NO Contact to the housing, no wear. It is all electronic and is high tech, doing many functions, operates only on battery, with Ford trembler coils shunted.
