Time to check antifreeze
fordcoupe
After reading the threads on block repair it reminded me to check the antifreeze in my three model A 's I found that one had a + freeze point temp. drained some out added full strength to bring it up was wondering how that was as I use 50/50 mix Remembered that on a club run the truck ran hot this summer coolant was low fellow club member added some for me his own mix called him to tell him that his mix will freeze when it it gets below zero i went over with my tester and found the same thing on his A drained and fresh fill with 50/50 so glad I checked. :)
