C CatMan1 Senior Member Sep 16, 2021 #21 Figured it out. The idle speed was higher than it should be. It also fixed another issue……dying at stop signs. Much better now!
A aermotor Well-known member Sep 16, 2021 #22 nkaminar said: Catman, Until you get a chance to repair the sector at the top of the steering column, you can slip a plastic or rubber hose over the lever to keep the throttle from moving. Click to expand... Shrink tubing works good. The model A has a lot of torque and will go at very low RPM's. Glad you got it worked out. John
