i`m considering pulling the belly button motor out of my `37 coupe, I`ve located a 52/53 mercury flathead EAC Motor, with trans, what is this motor from can anybody give me a clue I`m new at flatheads...what to look for....?
Rich
Essentially what you have is the last of the flatheads for the US. The last Mercs were rated at 112-125 HP. If what you have is truly a Merc engine (many flatheads had parts interchanged), and it's in good shape, you've got a great engine.
Jim
Oh man!! That's good news , I'm sure that '37 will be much happier with a new FH heart transplant! Put that SBC back in a Chuby. I'm not that familiar with the Merc engines, but I would see if it has a four inch stroke crank, bore it a little over, and maybe install hardened valve seats. Keep us posted on the conversion process with some pics, etc. Good luck! JM
Thanks guys, the engine is complete and together, with trans all parts there except gen/starter, been in a garage covered up for 30 years per the owner, are there any stampings on the block to verify.....? I`m trying to gather all the info I can so when I go to look it over I have a educated guess, I know that it is a crap shoot as far as being a cracked block..!
There's been a lot of talk about the engine. You didn't say too much about the transmission. Is it contemporary with the engine? I'm not too sure that a '49 and up transmission will work in the '37, especially if you want the traditional closed driveline.
This is where it will get sticky, I`m going to keep the ford eight inch under it with open drive line, not sure yet on trans, still looking for options, any recomendations at this point....
You can keep the 8 inch. Use a 48-50 F-1 three speed floor shift. It's open drive and will look like a stock trans with the floor shift. You will need to use the pickup bell housing also, as I think the Merc bellhousing is different. If the block has been sitting for a long time I would pull the heads and check for cracks. Hopefully it was not removed from a car due to a cracked block. I had exactly the same setup in my 37 coupe.
You have a bunch of guys here that will do what ever we can to help you get that Chevy boat anchor out of your Ford. Your car will never be normal, it must have emotional and self esteem issues. It's like somebody cutoff its ***** at one time and now your considering putting back on.
Your going to loose half your power for twice the money but once you go Flathead you'll never go back. You will find that Flathead people are the nicest people on the planet. All my very best friends own flatheads, the billet Chevy guys just seem to be a little to bitchen for me. I’m serious, it’s like they are from two different planets.
