Tillotson carb
Why do some A’s have a Zenith carb and others have a Tillotson carb? Is it by model or year?
All the OEM Model A's were either Holley or Zenith carbs (look the same, cast iron body, details differ like venturi and brass vs steel fittings).
Tillotson was aftermarket, but I do wonder when they came out.
We ran Tillotsons back in the 1960s so had to be before then.
Tilly’s were like a JC Whitney thing. You could buy a new Tilly for less than a Zenith rebuild. I don’t think that it was intended to be an upgrade so much as it was an inexpensive replacement.
Now I will throw gasoline on the topic and say that the Marvel is by far the best! LoL.
When Zenith stopped making A/B Zenith carbs, Ford started suppling Tillotson and Marvel carbs as replacements, even assigning Ford part numbers to them.
Do you know when the Tillotson X came out & when it got in the Ford books?
My 1950 Ford Book shows the A carb xuperceded by the B carb, but no listing for a Tillotson.
But from this thread & others, Tillotsons were on cars by 1960-62 so had to be in the 1950s somewhere
And you all know about Marvel Mystery Oil, right? Same guy, he created MMO because his carburetors were having problems with bad fuel etc. I don’t know how much money he made selling Marvel carburetors but he no doubt made more selling MMO. FWIW, if you had an opportunity to drive a Model A with a downdraft carb (that has an accelerator pump!) such as a Stromberg, Weber, etc., you would throw your updraft (regardless of which one) away.
WerbyFord, I have the Ford part numbers, but don't know the date they were introduced.
Tillotson was assigned, B-9510-A3. The Marvel Schebler B-9510-A2. The Marvel Schebler part number used for Model A was 8-2843. Some of this information came from an article by Steve Pargeter in the Restorer, July/Aug 1995.
No argument, but a friend running a Weber just had his engine fill with gasoline due to a leaky shut-off valve. So each type have their own issues.
Good lead thanks!
Found this, some fun info here, Zenith Model B style replacement for Model A but different venturi & needle valve.
https://www.fordgarage.com/pages/nosbzenithcarb.htm
