Tatanka
I visited my friend Bob to run through his '31 Deluxe Roadster's fuel system. Sediment bowl was clean and I pulled the carb for a check-up. Gaskets not bad and clean bowl. He's had some fuel leaking out the air filter/air intake when idling, so paid special attention to the float and fuel inlet needle. Needle & seat looked fine and no holes in float, but there was some corrosion on the pegs that the float pin goes through and one of the float tangs was a bit wide, so it probably dragged on the corrosion. Cleaned the corrosion and bent the tang in so all move freely.
And, his carb is a Tillotson, not a Zenith. What is the consensus here about the Tillotson carb?
