Tillison and Marvil carb
Depends on type!
For the Tilly, use 1". with upper half turned up side down, measure from gasket surface to top of float.
for Marvel, 15/16" with upper half turn up side down, measure from gasket surface to float seam, and the seam should be level to the gasket surface.
Hope this helps.
