B BashawT Senior Member Apr 13, 2012 #1 Just snapped one of my spring clip bolts reassembling spring. I noticed the nut and bolt were not hardened bolts so my question is how tight should they be and should I buynew hardened bolts. Also should I use a lock washer? Thanks guys!
Gary WA Well-known member Apr 13, 2012 #2 snug enough so they don't rattle, 1/4-20x2 3/8 with square nut. Judging stds show no washers.
30modelA Member Apr 13, 2012 #3 put the stick on weights on the inside part of the rim. or install dyna beads inside the rim
B BashawT Senior Member Apr 14, 2012 #5 Gary WA said: snug enough so they don't rattle, 1/4-20x2 3/8 with square nut. Judging stds show no washers. Click to expand... Thanks. That's what I ended up doing
