Since I experienced a problem in the rear end & differential on my 1930 Deluxe Coupe, necessitating the replacement of parts, and since I had the rear end pulled out from under the Model A, I decided to replace all the internal parts(bearings, gears, shafts, etc.)in the transmission. I have now installed all the parts, using RESTORER'S MODEL A SHOP MANUAL by Jim Schild and MODEL A FORD MECHANICS HANDBOOK by Les Andrews as my reference sources. I did use the "sealed" bearings, "baffles", "shafts with O-rings" and the "transmission shaft seal kit".
As I was assembling the transmission, I continually checked to make sure that everything turned freely in the case. However, after installing the front bearing retainer and rear bearing retainer, and torqued per the references, it became more difficult to turn the main shaft and main drive gear. At first I thought I had installed the "baffles" incorrectly, but that was not the case.
I should mention that I did install all the parts "dry", with very little lubricant used. Also, no "cluster gear thrust washers" were used.
Any ideas as to what the problem could be would be appreciated. Will the tight transmission loosen up after adding transmission oil and running it?
I earlier rebuilt the transmission in my 1930 Model A Pickup, again with all new internal parts, with no problems.
Thanks in advance for any and all suggestions.
