Off topic, but what's the deal with those wooden spoke wheels?
That's a Canadian AA. The wheels rear axle and drive line are different
than US trucks.
Bob
I took a autobody class 40-year's-ago from an old time body man that was an amazing metal finisher. That is all he had done since 1948. You definitely want a butt weld. You want the pieces as close together as you can get them, no space at all. The less filler rod you add the less warpage you will get.
He was teaching us to hammer weld with gas welding but there is so much warpage with that much heat the TIG is the way go. I just bought one but have not started practicing with it. When we gas welded we tacked one end and then quickly hammered it with a body hammer and dolly. Then tacked the other end and hammered it. Then staggered the tack welds every half-inch and hammered the tacks. Then weld a half-inch at a time and hammered it while its hot, you need to be fast. The move to a different spot while the other one cools down. If your really good the weld disappears. We had a one gallon can of this stuff called moistbestos which just by name I can guarantee you does not exist anymore. It was like Playdoh and you put it around the weld to absorb the heat from spreading further out into the sheet metal. Anything you can do to try and control the warpage. Eastwood sells a similar product but I have not trid s it yet. I heard people to say to use drywall mud. Anything you can think of that you can put around the weld area that will stick to the metal and absorb the heat.
We had piles of donated junkyard fenders to work on in that class. It makes a big difference when you can practice on metal you have no emotional attachment to. We would cut slits and weld them up. Smash dents and then try and metal finish them. If you want to learn mess with a junk fender. If you practice on a junk fender everyday for a week or two you will be amazed how much better you get. Watch the welding videos on youtube so you will know what you are doing wrong. The problem I'm having is with a cornea transplant I had because of a botched Lasik eye surgery. That one eye is so blurry I'm seeing double vision with it. Nobody has been able to fix it. I see two-welding puddles.
Terry, I think the difference between what we are suggesting and what you did is "metalshaping". If you MIG a panel, the weld becomes hard & brittle which makes planishing and stretching/shrinking almost impossible. There are some that will compensate for this shortcoming by applying extra thicknesses of body filler over the top.
Brent, The CO2/Argon shielding gas prevents (or it's supposed to) the hydrogen that makes the welds brittle. The welds break because they aren't penetrating enough. Too many "welds" are little more than "solder" , just attaching it's self to the surface of the metal. Or the H.A.Z. allows breaks away from the parent metal. In the first case, the weld must penetrate through. This must be confirmed visually. The whole welding process is a dance between heat and duration. Then all those little bumps must be ground. I have tried planishing and without some instruction, I have had no success. As I understand it, you're striking the metal with a relatively light hammer to bring down high spots. But it's kind of a glancing blow. This is the forte of the French blacksmiths who created the folds and wrinkles in the Statue of Liberty and the "Trench Art" that was created from old brass shells after WW2. "Metal shaping" at it's best! I believe the technique is called Repogee or something close to it.
Terry
Bingo, done properly MIG is fine. Of course, to be done properly, you must use proper wire, heat and shielding gas. CO2 is not the only one, 75/25 mix and TriMix is available also.
J
Brent, I confess to incomplete knowledge of all the chemistry of this situation, but I believe it's the hydrogen that causes brittleness in welds. Once this was discovered, a series of rods ( stick ) was developed called "Low Hydrogen" The most well known is 7018 but there are others such as 7014, 7016 and 7024. 7018 is an all position wire, while 7024 is basically for flat welding. Oh God, I'm straining the memory cells! It's been a while! Anyway, IIRC the purpose of the low hydrogen was to keep the the gas out of the weld. I don't believe it was the CO2 that was embrittling your welds. It may have been your cooling down of the welds after completion. MIG does cool much quicker. But thats because there is less heat generated. While the TIG may have a duty cycle of as much as twenty or thirty seconds and the accumulated heat slows the cooling down. The MIG may have a duty cycle of as much as 4 or 5 seconds and the heat doesn't build up as much, yet the heat at the point of the weld still generates molten steel, just not as much of it, so, you get a hard point at the weld. I'm just speculating on a problem I've never had. I hope this helps!
Terry
