tie rods
My opinion is Nylon/Teflon work great IF the ball they are next to is round and smooth. Polished balls really help the Nylon kits work well but will deteriorate very quickly if the ball is worn or rough.
when I took apart the balls looked new what a bonus. i guess any good grease will do? or sugestions as a good grease thanks
I like Staylube Boat Wheel Bearing grease, it is water proof, has a drop point of 400, and stays in place and does not run out like most grease with a lower drop point. I even use it to pack my wheel bearings and other grease locations. Been doing it for over 30 years and have had no problems.
Ron
I totally concur with Brent. They are an excellent things to do but you have to have good smooth/round balls. Any roughness will tear them up. I use them in all my service work when rebuilding front steering arms/front ends.
When all is right in the steering components it's amazing how easy a good "A" can steer.
Larry
Look new is not the right answer. A well worn ball may look shiny new.
You need to measure for roundness. If you can feel the bump with your fingers you need new balls. If you can not feel any edge of the wear then it is a judgement call. A few thousands of wear and a smooth feeling is ok, but there is a point where you may want new balls.
