tie rod rubbing
shark 81
20170511_105926.jpg tie rod.jpg[/ATTACH]
what has caused this ? the tie rod seams to be slightly bent and is rubbing the drag link. Is this fatal for the tie rod ? or just straiten it.
drives fine as is everything seams ok and nothing loose.
just rubs a bit.
thats got 2 bends in it - im sure it could be straightened but how did it happen?
drag link could be too low from a steering arm being bent down or possibly bent frame, could also be weak/broken front spring worn shackles etc...
View attachment 315504[/ATTACH]
just rubs a bit.
You could try straightening it but tie rods are relatively cheap~ $15 @ Snyder's.
My tie rod had been rubbing at some point. The gap between the drag link and tie rod was very close. Replacing the front spring helped but what really made a difference was replacing the drivers side steering arm.....along with a new tie rod....
Get a new one from Snyder's or other parts house.
The one I bought from Snyder's was solid not flexible hollow like the original.
The tie rod can rub on the drag link if the front spring is too soft...that's where mine was rubbing
ASaggyspring will cause the parts to rub...but won't put an S bend in the tie rod!:eek: I'd just find a better, or new one and also change the spring as well as SteveB31 suggested. I had to change the front spring on my 29tudor to solve a rub.
Brian w.
But ... a shorter pitman arm would:
Raise the drag link
Stop the rubbing
Make for easier steering
And allow for that sporty low suspension ?
Raise the drag link
Stop the rubbing
That all sounds good but the shortened pitman arm is only 1 1/2" shorter and the rub happens right up the front. Raising the back of the drag link by 1 1/2" won't make much difference where it crosses the tie rod.
By how much does the end of the drag link clear the brake arm that goes into the top of the brake. If it is more than it should be, the top steering arm might be bent down. Hard to figure how that could happen but strange $#!T happens over nearly 90 years. Also check the height of the front bumper off the ground on a level surface. That will tell you if the spring has sagged. I had one reset a while ago and what a difference.
a new tie rod will be ordered. I will address the springs if the new rod rubs. when I got the car it had big fat 8"wide tires on modern wheels. I suspect that it may have led to the bends .
thanks everyone !
Lane
your front spring is sagged. Replace the spring- problem solved
Steve @ bert's
I agree the tie rod seems to be bent... but I'll bet your spring like Steve says is sagging as well. Look at the car from the front. If you can't see 1/2 to all of the axle under the front radiator apron standing in front of the car a few paces then the front spring is sagged. We see this all the time and it's amazing how many bad springs there are on "restored" cars. looking at the spring I don't see spring leaves where they should be indicating the spring is weaker than it should be or someone removed leaves to "lower" it.
(see my last paragraph).
Do yourself a favor and remove the tie rod assembly as a unit, undoing the front nuts on the front of the spindle on each side. Back the nut off till flush and use a long large brass drift punch and hammer and knock the arm out of the spindle, and then remove the two arm and of course the steering arm off the sector shaft and the assembly out the drivers side.
You can then service properly the steering arms checking them out as well as replacing the bent tie rod. If the balls are ovalled replace the arms and install a steer eze kit. once installed and all work done do a proper toe in set.
There are many drag links that have flat spots on them from rubbing the tie rod and trust me.... they are NOT from bent tie rods typically.. they are from sagging springs.
Larry Shepard
