This is an intermittent condition. While running at speed the engine acquires a rapid ticking sound that I cannot isolate. Is it a worn timing gear and cam shaft action? It is not a wrist pin, ignition-timing or bearing knock type of noise. Thoughts? Is there a quick way to isolate a timing gear issue? Is it difficult to replace the timing gear? Thanks in advance for the comments. TQ
