Hemiman392
I have a 41 business coupe and a 49/53 engine from H&H ,Navarro heads and intake ,I told Mike at H&H what I have and he sent a balanced and drilled flywheel wit a 10” clutch and pressure plate. But no throw out bearing.Do I use the 41 t o bearing,or do I need to buy a different one ? If so which bearing ? On the exhaust I want to run duals,should I put a Vega steering box,if so which one? Which exhaust manifolds will work, or would block hugger type headers be better? Thanks for any and all suggestions and advice on these questions. Hemiman392.
