Hemiman392
I have a 41 business coupe with an engine from h and h flatheads that is a 49/53 . It has a scat 4 1/8 stroke crank .Mike at H&H sent me a balanced flywheel clutch and pressure plate. Do I use the same t o bearing for the 41 or buy a different one? It is a 10 clutch. This is my 1st flathead and know very little on what does and doesnt work.I also have a 47 merc complete with all orig running gear.i would like to say also that the build of the engine is great and his attention to detail is second to none. I am trying to install and get it running.and also I need to know would a Vega steering box help when I run new exhaust? If so,which box? And which headers or Fenton type exhaust manifolds? Lots of questions , lots of confusion. Hemiman392
