throw out bearing hub differences 1932/ 1935
I believe it will, but you have to use the permanently lubed throw out bearing and the operating fork 48-7515 may want to change the transmission main drive gear retainer B-7050 for the later style with a seal. The B model hub B-7561 was also used on the 32-4 model B & the V8.
Thanks for that that, reply was so fast, I guess Ill try and find the correct throw out bearing hub, but its good to know if I do get really stuck there is a different fix available.
