It is possible to perhaps get a longer linkage. Standard is around 10.5 inch.
I have one which I can adjust as both ends fit into a centre threaded section which allows correct length to be found for full throttle position. Or you can perhaps after careful measurement cut the rod and add required extension as to give full travel
Phil NZ
