Barners - the notch plate underneath my throttle lever is so worn that it's smooth (see picture). So it's not much use as there's nothing keeping the spring in the throttle linkage from closing the throttle down.
I recall fairly recently seeing someone offering replacement plates, which I assume are soldered to the steering column. I remember thinking to myself "good to know if/when I ever pull that steering column". Well, i'm going to be pulling the column (see my earlier thread about unequal steering effort) and this would be a good time to rehab it. But of course I didn't write down where I saw the replacement plate, and now searching through the catalogues I have, I can't find it.
Am I nuts, or hallucinating? Does anyone know if/where those replacement plates are available? Or should I hunt for a column with good plates, and attach it to my steering box when I rebuild it?
Thanks all.
JayJay
Thanks all.
JayJay
