Threads per inch on Model T hub
oldmotorsguy
What are the threads per inch on a Model T hub? My thread gauge has 18 tpi, 20 tpi and 22 tpi. None seem to really match up very well with the threads on hub.
If I just mike out an inch and manually count the threads, it looks to be around 19, does that make sense?
Thanks Tmodelman. I'm off to the races with this info.
PS: why is it that you joined Ford Barn in May of 2010 and are considered a 'senior member,' while I joined a month later in June of 2010, and am only a measly, run-of-the-mill 'member?' :eek:
