1930pu Senior Member May 27, 2020 #1 Hi, I am working on my 19309 steering and wondering if the shaft could have been cut on the steering wheel end, the threads measure about 1/2" from the shoulder to the end of the shaft, it is just enough for the jam nut to fit. Thanks
kenparker Well-known member May 27, 2020 #2 sounds about right. a thin nut goes on the e d of the shaft. nut 3/8 to 1/2 "thick.
burner31 Well-known member May 27, 2020 #3 One maybe two threads above the nut...if that. From your description it sounds good to go, tighten it down good.
B Brentwood Bob Well-known member May 27, 2020 #4 This threaded end is easily ruined. Use care , good judgement, and a light touch.
1930pu Senior Member May 28, 2020 #5 Thanks everybody, I found out it is ok, glad I don't have to repace it. Thanks again... Jim
