Chris
Hey guys,
I am putting a new gas tank in my 1933 Ford pickup. I have the tank loose but I can't drop the tank all the way out without taking the filler pipe off. I also need it to go on my new tank. It looks like the filler pipe goes into a sleeve with notches on top and that sleeve threads into the tank. How do you remove the pipe from the tank? Is the notches on the sleeve for tapping/turning the pipe? I tried tapping on it a little but it is not budging and I figured I should make sure I am doing it right
Thanks!! Chris
Thanks!! Chris
