Thread type in block
OK...weeks of research...finally went to what should have been the obvious first stop, before the Ford apprentice School reference book, before the Ford engineering book..."Shop Theory". I believe this book was first put together about 1934, and it is very easy to find because huge numbers were reprinted during WWII and used nationwide to train new people flooding into war production.
So...most modern threads are classes 2 and 3 of the current system, class two being most of the hardware on your car and nearly everything else around us, class three being tight fit.
Tha 1930's standard used by Ford and described in the "Shop Theory" book has FIVE classes. Scroll up and look at the Tap descriptions in the drawings...Marco's early 1929 drawing shows class 4 tap, Vince's slightly later one shows class 5 tap. I am assuming the number represents class of fit designation as I do not know what else it could be!
Ford cited the National Screw Thread Commision (Stand up and salute!) as the source for its classes, and as I said I believe this list was probably first put into this Ford book in 1934. My copy is from 1942 printing, still before unified thread and SAE classes and such:
Class one: Loose fit
Class two: Free fit
Class three: Medium fit
Class four: Close fit
Class five: wrench fit
This means, as experience shows, that the 5 used on most A's and probably up to 1948 (same everything on studs) cannot be cranked in by hand on good threads with proper rolled original studs.
Probably the majority of A-B and V8 block threads have been wallowed out by now by well meaning machinests wielding modern class 2 taps, hence leaks, slanted studs, need for Loctite and Permatex, etc. I've killed a few in my past...
Of course this all goes with rolled thread, carefully made studs formed to seat into the surface formed by that second shallow drilling noted in the drawings.
Question for those with lots of archival drawings...which class is the "normal" one for the 1930's, used for less critical clamping with common bolts??
From my 1927 Machinery's Handbook They listed the 4 classes but with sub-divisions such as in #4 or wrench they list a Heavy and light. Heavy being used for large items such as steam boilers and light for aircraft and automobiles.
In 1927 the National Thread commission list 4 classes
Loose
Medium
Close
Wrench
They also listed many more sizes than the SAE or Unified. Such as the air bleeds on Winfield carburetors use a 9/32"s x 32
Class two: Free fit
From my 1927 Machinery's Handbook They listed 4 classes but with sub-divisions such as in #4 or wrench they list a Heavy and light. Heavy being used for large items such as steam boilers and light for aircraft and automobiles.
Loose
Medium
Close
Wrench
