This Is Embarrassing
I don't like for my engines to run that cool.
I agree, You need to run your engine hot enough to boil off condensation and unburned fuel byproducts that naturally accumulate within the crankcase. If the oil does not reach a high enough temperature, these contaminants remain suspended, leading to sludge formation and accelerated engine wear.
Causes of overheating:
  1. Bad radiator
  2. Loose or worn out fan belt
  3. Too retarded or too advanced timing
  4. Too lean fuel/air ratio
  5. Clogged radiator and/or engine
  6. Rust, scale, sludge coating engine cooling cavities
  7. Bad thermostat (enlarge holes in flange)
  8. Bad water pump (highly unlikely)
