Tore down my 34 pickup banjo rear to inspect and replace the parts that are worn. Looks like one axle needs replacing (which I have) but curious on the ring gear. You can see from the pic there is some scoring on the axle mating surface of the ring gear. Is it usable or too badly scored?
Also see pics of the axle that matches up with same surface. Axle pic also shows a lot of pitting on tapered end.
Opinions on the axle and ring gear viability are wanted. Thanks
