J jhtdon Junior Member Dec 4, 2013 #1 I am installing one on my 38 PU flat head. Is the taped hole in the middle between the two carbs. a vacuum port for the wipers? Thanks for your help! Don
Walt Dupont--Me. Well-known member Dec 4, 2013 #2 I just install one of those intakes on an engine I'll be posting pretty quite. That hole between the carbs is a vacuum hole I ran a 3/16 line from that to the crab dist, you could install a T fitting and run the wipers there also. Walt
J jhtdon Junior Member Dec 4, 2013 #3 Thanks so very much! It will be much easier to utilize the bench to set it up.
K Kerk Well-known member Dec 5, 2013 #5 Walt just finished my 59 with the crab and a P.M.7 using (2) 97s and it sure sounded great .
Walt Dupont--Me. Well-known member Dec 5, 2013 #6 Kerk said: Walt just finished my 59 with the crab and a P.M.7 using (2) 97s and it sure sounded great . Click to expand... Get the 25 pickup finished Kert, I want to see if that engine will make it up here in Me. next summer. Walt
