wunderwerks
Converted my '49 to an 8 volt battery. Cranked up the regulatory to 9.2 volts output from the generator. Was told my many the 6 volts bulbs would be fine, they would just shine brighter. Two hundred miles later all four turn signal filaments are burned out which also means the brake lights are gone. Don't think they make 8 volt bulbs. Suggestion was made to put an in line resistor on each wire to reduce the voltage to 6 or just run all lights through a separate voltage regulator. Don't know what would be best?
