The Model A engine cooling system was designed to operate in the 160 to 170 degree range. The siphon design flow of this cooling system needs about 180 degrees at water pump to really get things moving. However, the other parts of the engine should be cooler.
You want to make sure your cylinder walls along with the rest of the engine stay cool. One thing you don’t want is oil flash on lower cylinder walls. Heat is your engines biggest enemy.
If your car has a correctly restored and well maintained cooling system. There should be no need for a thermostat or adding a pressure system. 90 years of service.
I believe 160 is too cold, so I use 180.
John
with out a thermostat, my temp gauge will not move above 100
Please remember if you are running a thermostat. When it is closed your water pump is trying to pump into a blocked pipe. There is no by pass for coolant to flow as with modern cars, you could get HOT spots in your engine block until thermostat opens, 180 degree thermostat will not be fully open until around 200 degrees, water pump in Model A is designed to only help at higher engine speeds, therm-siphon is main source of engine cooling. Hot spots, oil flash, things to think about.
Heat shortens engine life. You might get a little more HP, but at what cost. Enjoy.
One point to your comment, the thermostats used in Model A's do have minimal by-pass holes, usally two, you can see one in the photo, the other is on the opposite side.
You can, if you disire, increase the size of the by-pass holes = increasing by-pass flow.
...Normal operating temperature is 180 degrees at upper hose (water pump), 160 degrees at lower hose (radiator outlet bottom of engine).
I'm curious what your source of information is for those numbers. In my experience, "normal" operating temperature without a thermostat varies all over the place, and definitely won't get up to 160 on a cold winter day.
Steve
... Normal operating temperature is 180 degrees at upper hose (water pump), 160 degrees at lower hose (radiator outlet bottom of engine). ...
Steve
.. I try to give my honest view on questions members ask based on what I believe to be correct. Question yes, we all should ask why. If I am wrong, give me what you believe to be the correct figures.
