My story
- Car runs fine
- Someone tells me I should have a thermostat
- Bought one and put it in
- Stuck closed
- Overheated
- Took it out and threw it away
- Car runs fine
Just my experience - ran fine for 80 years - adding one more thing to go wrong
I run a 180. People seem to think a 160 will give cooler temps under hood and more margin for boilover, but I partially disagree.
You will not really experience a big difference in either under hood temp or boilover safety margin. The underhood temp is a function of the radiated heat from both the engine and the radiator. A cooler engine (160) will actually produce more waste heat into the water than when run at 180. The cooler 160 block will radiate less heat, but the radiator then needs to dissipate slightly more heat. The overall temp underhood may change less than 10 degrees despite a 20 degree difference in 'stats.
Boilover margin? If something is awry that is going to overload the maximum dissipation rate of the radiator, it doesn't matter is you start at 160 or 180. It's gonna happen. A cooler 'stat isn't a miracle fix.
The added benefits of the 180 stat are your oil will run hotter, getting rid of moisture in the oil and crankcase and improved gas milage/ drivability from better fuel vaporization and more complete combustion.
In the 60's I used to change the stat in my modern car ('60s car = modern) in the spring and fall between 160 and 180. I now think I was wasting my time.
I have had the same 160 degree thermostat for 20 years, it is 160 because it is what I found --in the trash at Hershey one year, it is the bi-metal coil type made to fit in the hose.
My car went from 18 mpg to 23 with just that change.
The car ran fine without overheating before the tstat.
I also remember helping my Father change 160-180 for summer-winter.
Thermostat in my Sports Coupe (160) Certainly makes it more drivable in the cold and I think probably increases gas milage. In my phaeton I went to install one and found a whole lot of brass guaze inside the top hose. It had obviously been put there to catch the rust of which there was some. I'm a bit worried about the thermostat blocking up with rust particles So decided against it . Am I being over cautious ?.-Karl
