wensum
Maybe not related to your problem but I'm curious to what mods you made to get 120 psi compression?
The motor is bored to 100thou oversize which was necessary because of the state of the block. It has a 7:1 Winfield reproduction alloy head which had to be relieved to clear the larger inlet valves and also machined to allow piston clearance.
Clearly it is the head alone that contributes to the 120psi, although the large bore must also contribute a little.
It also has mains pressure oiling, counterweights on the crank, lightened flywheel, reprofiled camshaft, twin Stromberg carbs off early Holdens and shell bearings.
So far, mechanically reliable and quiet, but surprisingly grunty although lacking the very low rev torque of a classic Model A
Keith
