Larry Brumfield
Who needs an ol' thermostat anyway?
Under certain conditions the presence of a perfectly functioning thermostat, even one rated at a lower temperature, in the system of your Model A can cause overheating!! .... Notice I said "perfectly functioning." ... and "lower temperature."
If the temperature of the water in the head and engine goes higher than the rated temperature of the thermostat, the thermostat will open to try to compensate. Once the thermostat has opened as far as it will go it's allowing the maximum amount of water that can pass through it.
If the temperature continues to rise (driving fast with heavy load up a steep hill on a hot day for example) the thermostat has done all it can but its presence has now become a restriction. If the incoming water from the radiator is not cool enough to overcome the heat, the water will stay too hot. Changing to a cooler thermostat might be the remedy. Or maybe change the radiator ..... or maybe not ... it's never overheated before.
Nevertheless, at this point if the thermostat were not in the way, the hot water in the head would pass on through easier and if the cooling of the radiator is sufficient, the water in the head and engine will cool down some.
I've seen people buy Model A's with thermostats and have overheating problems at higher speeds. They try other, cooler thermostats with no luck. Then they get mad and remove the thermostat and guess what? ........ the overheating problem stops!
Now what does all this mean when trying to determine whether one needs a thermostat for their Model A?
The answer is simple.
Install the thermostat of your choice and if the engine never overheats regardless of the load or conditions and otherwise regulates the temperature correctly, then you've got it made!
Enjoy the benefits.
Larry B.
Enjoy the benefits.
Larry B.
