Isn't the radiator inlet and the engine outlet the same
Bob
On Minerva, I just slipped it in the top of the top hose & it was invisible & worked FINE. It was the type with a sleeve spot welded on to it.I am talking upper hose ,close to radiator neck. I thought the water flowed into the radiator
Same here!I have found using a thermo/housing from Vintage Precision Inc. makes this a snap. It has the thermostat inside and has predrilled holes for a temp gauge and heater hose connection. Their phone is 800-486-0021. I have these on 2 of my A's and they work perfect. I got tired of breaking the originals. Good Luck!
My post is about the temperature at which a thermostat opens. I have a temperature gauge with mine and it seems that it starts opening where it should at about 160 degrees, but is not fully open until the water temperature reaches about 190 degrees. Has anyone else notice this sort of behavior?
It is the type of thermostat that is attached to a cylindrical sleeve so that it will stay straight in the hose and can be clamped in place using a hose clamp on the outside of the hose. I am sure that I bought it from either Bratton's or Snyder's.
You are correct...reading this on my phone at work I must have missed the radiator part lol...my badnow I feel dumb
