The headlights on my original 6 volt Model A were just not very good. The reflectors had been messed with and would need re-silvering or replacement, whoever had the car before me did a wiring loom upgrade, that looks original, everything worked right, just very dim beam headlights.
I started looking around, priced re-silvering, priced new reflectors, and then started getting dangerous and looking at other alternatives.
Here is where the wrong path taken started………….
I found some sealed beam adapters that would allow me to install sealed beams in place of the
Original reflectors and some sealed beams, which now are only available in 6 volt has halogen.
I looked at the current increase and the wiring and did some calculations and I was borderline on current but I do little night driving and it seemed workable and the Cheapest way to get the lights working so I could drive at night.
I did the conversion, and the lights worked fairly well. Some had posted on this that the sealed beams do not provide a good light pattern and that is true.
Next, I found that I had to crank up the 3-brush gen in order to not be going negative on the ammeter with the lights on low or high beam.
Next, and obvious, I found that driving the car during the day, I was overcharging (boiling) the battery.
So next, I installed a modified 6 Volt Delco Remy alternator, and solved the charging problem.
The other night I was out with the low beam on and tried to blow the horn. Could not get it to ahoooga! Parked and turned off the lights and the horn worked perfectly.
So, the last item down the wrong path taken will be to add a 6 Volt VW relay on or near the Alternator, to provide a separate power and ground for the horn.
There were many ways I could have gone, yet once started down the “wrong path taken”, there just is not much left to say other than if I had it to do all over again, I would not feel the need to be writing this!
