Harms Way
I posted this on the HAMB before,.... But thought you guys might also enjoy this..........
Now I know for most of you guys this is just a rehash,.. and you all know this,... but for some this might help.
Back in the 70's I built a spring spreader from plans in Rod Action magazine, hooked it up to a partial unpacked 40 rear spring and started cranking away, well when the spring was spread almost far enough to get the shackles lined up, the stupid thing folded up like a cheap lawn chair, the spring went flying and just about took my head off.
A old friend of mine had been using a variation of this method for a very long time, this isn't new to a lot of you, but I have found this to be the safest easiest way to mount and dismount a transverse spring especially if you are working alone,............. I just happened to have a camera handy when I put a front spring on a dropped front end, for a friends chassis.
So for those of you who are interested in this simple process, here is the step by step process.
First you take 2 large beefy "C" clamps and put them on either side of the Pack center bolt and reef them puppys down,.. then get a "All Thread" rod, 4 large flat washers, and a couple nuts for it, unbolt the center bolt ( or cut the head of it off ) remove the old bolt and replace it with the All Thread, 2 washers on top and two washers on the bottom and tighten up the nuts.
