my mistake , read the post wrong, the guys are right,when retorquing torque to max specs, do not loosen the bolt or nut, sorry, im old lol, if you really want true torque, take a bottoming tap with grease applied in the flutes to catch the particals that will be loosend up, run to bottom to clean threads, same with the studs, run a dye over the threads, then lightly oil bolts or nuts and procede to torque, if you dont do that your not getting a true torque reading because of the added resistence of dirty threads, check torque charts, two different readings for wet and dry totque
