The Official '32-'34 Truck Thread
here are two i really like. john jackson is the master!
-danny
Work in progress - going back to trad look. Going washington blue with black guards. After Danny's post I'm real keen on widening 18" wires I have.....
Bruce
My son's latest 1932 BB truck rescued from a N. Dakota pasture last October....
Im building a budget drag racer from a 34 cab I had given to me. Heres a few picks of the slant chop my dad and I did the other night! 4" out of the back and 6" gone up front. Didnt get doors with it so Im on the hunt for some...any leads would be appreciated! Thanks
32 Truck we got in ND
A few more photos of work on my 34 pickup
32bb ford; x cab,jag rear,78 f350 disks brakes,392 hemi,700r. On road sense oct 2010.
Here's a great looking truck. I took this picture at the Horseless Carriage Club Holiday Excursion last week in Pasadena, CA.
I remember this thread from the summer, but don't know why I didn't put a pic or two of my '32 B pickup back then - anyway, here they are. Ignore the Ill. license plate - that was just stuck on for looks while I waited to get it registered here in England. The truck came from NJ back in mid-2010.
nice, tasteful, but different!:d:d:d like how you did the opening in the hood.
i am a little late with a reply but;i cut the required louvers,to be removed about one and a half inch above the opening i wanted, 11 louvers in may case,if this cut is straight and in the right place it makes the job a lot easier. I cut the lower section of the hood 1 inch below the bottom of the louvers to be removed ,and moved this section up to create the opening i wanted. I spliced the louvers close to start of the flair on the section i moved up,welding the splice close to the flair made it easier for me to control alignment,warpage and makes the splice less noticeable. After cutting splicing and welding, i fabed a frame from half inch sq. Tubing and welded it on the back side of the hood as a stiffener.i used a mig and am only a fair welder.ps i used a practice hood.good luck ed
I may be too late but might anyone have a set of doors for a 32-34 truck? Am searching for a computer illiterate friend....it's his childhood dream project and he's 69 years old....
Any/all help is welcomed. Thank you
Can any of you fellows tell me how the gas gauge operates in my '32 BB truck? I've cleaned up and re-soldered a tiny crack in the tank unit, and returned it to the tank. however the tiny steel line (running to the gauge) is rusted off and clogged shut. So I will need to replace it. But it would be helpful to understand just HOW it works. I'm now wondering if the gauge will still work. Can you help? Also, is the tallest tube on the sending unit (and coming out thru the bottom) supposed to be an OPEN air vent? Thanks.
Cigar, take a look in here. I know there are doors available, but upwards of $1K for a decent set
Dave,
Here is a link to a helpful site:http://www.fordgarage.com/pages/32fuelgauge.htm
You can also pickup the 32 Service Bulletin at any repro vendor, ie LeBonney Baron, Mac's, Dennis Carpenter, C&G, etc... The service bulletin covers the fuel gauge and related system in detail.
To your last question, yes, it needs to be open.
Keep V-8ing and 4-banging!
Out on the road now, ready to swap out for a drop axle. One from Sid's can't be far off in my future. But in the meanwhile, happy motoring:
