Larry Jenkins
When I took the flywheel off by taking out the four hex head, drilled bolts, I saw that all for of the heads had wear marks on them, indicating some kind of interference.
If this is normal, can I take a skim cut on the bolts heads using my metal lathe to get the proper clearance?
Any ideas why they all have marks on the heads of the bolts? I have a new clutch plate ready to install.
Thank you!
Larry
Thank you!
Larry
