KULTULZ
Wanted: 1 driver quality set of ( 4 ) '60 dog dish hubcaps. PM with info.
Check EvilBay- C0AA 1130-C
True but also Ford ran batches of intakes, heads ect You could very easi;y have parts with date codes 2-3 months older than the build date of the car I did read that whole article, very interest but nothing really on numbers matching Maybe you could clue me in on what numbers are supposed to matchAgain...... a statement such as this is IMO.
To have a correctly assembled car, the Casting ID Nos (assembly parts not service parts), Date Code And foundry code must be correct or it (FORD-LINC-MERC) is not a NUMBERS CORRECT CAR. It must also match the build sheet if one is available or the owner may be hiding it.
Take for just an example, a 61 FORD 390 4V 375HP that came through with the Tri-Power in the trunk for dealer assy. Both engines (375 4V or 401HP 6V) will have the same engine code). The seller would need a factory build sheet to claim the car was a true 3X2 401HP.
ADDED INFO-
Here is one example of determining a MATCHING NUMBERS car-
http://www.vtohtx.com/M_Code_3_page_Fact_Sheet__v2_.pdf
Purist collectors WILL INDEED demand correct date codes and casting numbers on certain rare Fords. Also, there are certain numbers stamped into high performance blocks, for example, that identify them as such. A friend showed me this recently on a Super Cobra Jet block which allowed the potential buyer to identify it as "the one" he had when new. I agree that some GM models can have matching serial numbers such as the same as the VIN on some components, but I think most do not; I'm sure someone will correct me if I'm wrong. I think I'm right that not very many GM models can claim this other than that, like Ford and MoPar, certain components can be identified to correct models but not a specific car or truck.
Remember travelling along the Gulf Coast to a New Orleans college bowl game in '66 with three of us sitting up front in a beautiful '60 Sunliner convertible. To me, the '60 Ford is one of the old car greats!
The car was unique in that it was powered by a 260 CI and was slow but, oh, did it get attention!
A 260? It would have had a 292 or 352 originally. Why would someone swap in a smaller engine that would not fit the mounts, the bellhousing, the exhaust, the wiring, etc., etc.,?
Could have been a 223 ...
I worked with a painter in one dealer that had a beautiful 61 STAR. He popped the hood one day and it had a 292. Sorta like getting married and going on the honeymoon and finding out she is frigid ...![]()
Yep, a Starliner could be had with a 223 in both 60 and 61.
