Steve Wastler
A steering stabilizer in my opinion is a band aid. Why hide a problem, something isn't right somewhere, and needs fixed.
Poor Ackerman will never be the cause of bump steer, but it will cause the "inside" tire on a tight turn to scuff around the corner. Ackerman needs to be correct because the tires turn on different radii going around a corner. Death wobble and bump steer are two different things, loose components and/or poor alignment can cause wobble, while bump steer is caused by the drag link and wishbone (or radius rods as on hot rod) swinging in different arcs. If a longer pitman arm is installed and the wishbone mount remains the same you may encounter bump steer.
After 29 posts and a heck of a lot of work the poor guys car still isn't fixed.. That shouldn't be.. This isn't [or shouldn't be] hard to find or fix.. If everything is tight and adjusted correctly the car should drive as intended.. Something is being missed.. It appears a fresh set of eyes and hands need to wander around that monster.. I'm beginning to wonder if there really is a problem.. A 'man-hole' was mentioned; after running over it does the vehicle really go into ' death-wobble/shimmy' mode or does the bump just cause a hard jar of the steering wheel ?? If someone thinks that caster is a concern then just put the ' spacer washer' under the ball which helps reduce caster a bit..
I have been trying to help the original poster with his wobble problem. We have done all the things that he has mentioned. When the car goes into its death wobble, all the steering linkage moves an equal amount, both wheels wobble back and forth and the linkage moves clear back through the pitman arm. When it wobbles, the steering wheel does not seem to shake as violently as the rest of the steering linkage. He now has a gentleman helping him that knows Model As alot better than I do. They seem to be making some headway at correcting the problem a little at a time. There isn't much left but the steering gear box.
Why would you ask if there really is a problem? Of course there is or I wouldn't be posting here. Anyways Thursday we pulled both king pins and put everything back together. I ended up tightening the drag link a couple more turns. The car went out today and drove over every man hole cover or bump I could find and I'm proud to say it did not wobble or shake or anything. I also tightened up the bolt that holds the pit man arm on as well and that took some play away. So who knows if it's truly fixed but I did a lot of driving and it was so smooth. So maybe it was a combination of everything, but hopefully I am in good shape now. Thanks to everyone who offered suggestions, I think I did them all. Lol. Too bad it's October and the driving season is about over.
