Tinbasher
Ok So 5 deg's is what your looking for. I'd check the Radius ball and make sure it not worn. Also that the ball is mounted properly. If the upper plate is worn or missing this will decrease the camber. If all of this is good and solid then you can take the car to a Heavy truck alignment shop that will have the tools to bend the axle.I'd check for worn parts first, then a straight and level frame. If that's all good then go for the alignment work. JP
