Tom in TN
Well, after 3 weeks of struggling, the starter is finally out of the car.
How did I get there? Holy Cow what an ordeal.
Took the steady rest bolt out
Removed the nuts of both motor mounts
Used a bottle jack and vertical 2x4 to lift on the right front corner of the oil pan rail – just behind where it is kind of thin.
Jacked the engine up about an inch
Removed the radiator bolts so it could float upwards as needed
Removed the passenger side motor mount.
Jacked the engine up another inch.
Took the brush guard band off the starter
Rammed the starter towards the front of the car, between the A-frame and the motor mount bosses and it came far enough that the starter nose came out of its hole and pointed the drive downwards and dropped the starter out the bottom. FINALLY !!!
At least I now know for certain that the starter IS the problem. Looking through the brush cutouts, I see some very short brushes, some severely worn commutator bars and a couple that are dulled and rough. Turn the armature by hand and you can watch the brushes bounce up and down as they ride over the dulled bars.
For those that have expressed their opinion and given advice, I thank you one and all….and curses on the Ford Engineering team who didn’t design this to be easily removed.
