Since shout outs have been given to deserving vendors and shops, I figured I'd do the same for a great place in Minnesota. I visited their shop this summer when visiting a friend in St. Paul. It's in Forest Lake, which is a bit north of St. Paul.
I had decided that the carb on my '54 (original 239 engine and carb) needed someone better than me to make it right. I put a kit in it back when it was new (to me) and that helped, but it eventually needed an expert. The carb was identified by Daves55Sedan on this forum as an "EBU" so many thanks to Dave, as well, also for that info. (Who knows what kit the parts store gave me way back when.)
My carb gradually started running very inconsistent, and I suspected that the idle mixture screws were bad, among other things. I was right. I was also worried that the seats for the idle mixture screws were messed up, too, but the Carb Shop said they were OK. I'm glad that the seats were still good because that meant I could keep the original base for the carb. The rebuilt carb now runs very smooth, and more importantly...consistent. No fiddling with mixture screws every time a drive the car. Very pleased.
Something I forgot to ask them: Would manual choke carbs back in '54 have come originally with a fast idle mechanism? My carb doesn't have one, but I don't know if it might've been removed. I suspect it never came with one. Also, did they even have automatic chokes in '54?
On my '61 Merc I use the original fast idle setup with a simple aftermarket manual choke that replaced the original mechanical automatic choke. This arrangement works real good for me. BTW, the turn around time for getting the carb for my '54 back was GREAT - about a week.
https://www.thecarburetorshopus.com/
