I saw it somewhere but can't remember where. How do you test a coil at a flea market with a meter to see if the coils inside the box are shorted? Thanks.
If you go on Steve's link, but then search for John's Coil Beeper that is a fool proof tool for the job. It fits in your pocket and all you do is touch it to the two side contacts if it is good it beeps, if it doesn't beep salvage the wood if it is good and chuck the rest.
If you want to use an ohm meter, click the link below and it will give you the readings you should get.
