By clamp on I assume you mean an inductive pickup clamp. I like to remove the wire and put an accurate ammeter in series to check the amps. I don't have an incuctive pickup to check it against for accuracy, but I've always thought an inline meter was the best way to check. I do have an inductive meter that you lay against the stater cable for starter draw, or move it to the other notch to check for generator output, but for generator output I figure it's a rough estimate and mainly shows whether it's working or not.
